Re: How heavy of wire to use
Just trying to help. Not sure what you don't think people will know or at least what they can find out. It's pretty easy. They even give you help right on the page for every item.
voltage 12v or 24v - drop down menu - should know that one
load in amps? should know that one if your wiring anything
length - duh - how far is the wire you are running.
voltage drop- most important one to figure out. Read their help on the right with that one. It tells you what you want to know.
type of load - gives you two options - fixed or variable. again see help
temp rating - not that important for general appications- you can use typical, again see help
Done - what's so hard? If you are doing the wiring, you should know these things, otherwise let someone else do it.
