NathanFinch
- Mar 2, 2010
- 4
Alright, I am new to the thread and never posted on a thread before so sorry if I sound a little dumb.
Bought a 85 Glasstream with a 85hp force on it about a month ago for a steal (my first boat) and the middle carb was sticking so I had it rebuilt. Finally got it in the water and the first 3 times out it would run in Idle but would die out when you gave it throttle. Seemed as though it was not getting enough gas when it went into gear. After alot of tweaking with a few friends it finally would run but stayed in gear even at nuetral position. Ran a little weak also (or to what I thought it should do). I have changed out the fuel lines, ball, rebuilt the carbs (all three now). It seems to run fine hooked up to the hose but in the water it has started dying when you give it throttle, again. It seems to want to kick into gear at nuetral also. Could this be the cables needing adjusting or what should my next step in troubleshooting be?
thanks
thanks
