45 HP mariner running on 2 cylinders
jdmm61480
I have what appears to be a 1987 45hp mariner serial# OB201809. The first thing is the year correct? I am not getting any fire on the bottom 2 cylinders #3 and #4. Now at first i thought maybe the coilpacks so i swapped the #1 and #4 packs and problem did not follow. I had fire on 1 and no fire on 4 still. My next thoughts is that the switchbox has failed but im not sure if its that or the stator. What is the easiest way to determine the bad part?
Laddies
Banned
Re: 45 HP mariner running on 2 cylinders
1987 here's the test for the system
jdmm61480
Thanks,
I swapped the red/white with the red and the blue/white with the blue and the problem remained on the bottom two cylinders. Guess i need a power pack or switch box (whatever you want to call it). Anyone got a good deal on one?
Faztbullet
Here is schematics to test that pack, likely diode failed from bad ground on coil or coil internal ground bad..
