I purchased a 2003 Tracker pro 175 in what appears to be excellent condition. The seller put in a brand new marine battery from Kragen 24 MD-DL MCA 685 (starting battery/gave me receipt verifying just purchased). I happened to have the exact same battery (1 yr old) I use on my other boat and I put it in for the trolling motor/trim/fish finder/etc. Both batteries fully charged. Took it fishing yesterday (about 7 hrs). Engine started fine first 10 locations but then wouldn't start. (Running time between locations, 2-12 minutes each). Let it sit for 30 minutes and it started but engine died while at dock at idle. Not enough juice to start again. Checked it today and it needs to be charged. My used battery worked trolling motor & everything else fine but also wouldn't start outboard on the water when I switched the battery leads from new battery to old. It doesn't seem like starting an outboard 10 times should drain the battery. Any ideas? Why didn't the other battery start the outboard, but still worked the trolling motor. I know the cranking amps required to start is much higher than running trolling motor but it didn't even make any noise when I tried to start it.
