We bought a boat with a 1987 Yamaha 150 last fall.
Was running it with the ear muffs on the other day and may have turned up the water too high as it quit peeing out of the hole.
Figured it would be a good time to change the water pump so pulled it apart and think the new on is in corectly. Made sure to put the housing on so the impeller was bent the proper direction. One thing I am not sure of and can't see in the pictures of the service manual is under the bottom plate there is a brass looking piece that looks kind of like a top hat with a hole in the top for the shaft to pass. I put the brim of the hat looking piece against the thrust bearing and the smaller area up toward the water pump plate. Is that correct?
Didn't notice any type of seal at the top of the pump housing where it connects to the hose. Guess when you put it together it is just going to hit the hole in the hose or is there a way to pull the hose down to connect to the pump housing?
Going to pull the lower unit back off next week and looking for any ideas to try or what I may have done.
Thanks in advance...Sonny
