I've searched the group and found a lot of answers, but......
I have two questions that I can't seem to find,
1. I have a starter battery attached to a perko switch with an unknown size gauge wire. I am planning on adding a deep cycle battery with a #4 gauge wire. Does the wire gauge in a dual battery setup to a perko switch have to be the same? Any potential problems with the different sizes?
2. In a general dual battery setup, battery one (switch 1) is to start the boat and battery two (switch 2) is for accessories etc. I've read that when you start the boat, you switch to one. When you are on your way, you switch to both to charge both battery. My question is why don't you switch to both when you start your boat? Then you won't have to worry about accidentally switching to off.
just need a little clarificaiton.....thanks for you help!
