this is likely a silly question, but i couldn't find a good answer.
i'm in the process of adding a switch, ACR and second battery. where should I buy the wire. locally i've got a West Marine, Bass Pro Shop, Grainger and the usual Home Depot and Lowes. i'm fairly proficient with a soldering iron and i've got a heat gun so i can terminate the wire myself. i've seen some wire at Bass Pro (14ga) which seemed overpriced ($25 for a small spool) compared to the same gauge at Home Depot for $5. Obviously, I'll need larger wire for the high voltage stuff, this was just an example.
So, do i need to pay the large markup on "marine" wire that I'll likely find at West Marine or can I go to Grainger or Home Depot and get the proper diameter wire which I will terminate myself? Thanks.
