Re: I need some help
if your putting fuel in it up to the filler neck then yes, your putting too much fuel into the tank....you should leave about an inch of air space when filling up on a small tank like that...
also, if your putting in cold gas and fill it to the brim, when it warms up in the tank out in the sun it will purge gas out the vent hole, another reason to leave some air space in the tank...
of course, if your gassing and going, its not a big deal, but if you have a drive on a warm sunny day to the boat ramp after hitting the gas station your apt to see some moisture (from gas) on or around the cap
