How do I tell if my fuel pump diaphragm needs to be replaced? Early 70's 55hp magneto ignition, single carb.
If the pump is in good enough shape to start and idle smooth and run in the lower ranges fine but is not good enough for WOT running, how will it act? Would I expect it to just have a significant lack of power at WOT or should it be sputtering and missing?
