Hi: I have a 1987 225 Johnson that has the first three piston's
at 75 psi compression then two @ 70 psi and one at 68 psi the engine is running pretty good but I'am a bit worried about the low compression?
Those readings are too close together; are you testing with all the plugs out? Is the engine warm? Is the engine properly lubricated? Are you using a screw-in tester?
