pottscreek
- Feb 21, 2010
- 3
1984 Johnson 115hp
Okay so I just had this motor serviced rebuilt carbs, new spark plugs and wires, new impeller rebuilt water pump, compression was good and new gear oil. today after running hour and half some mins after all this work running at 5600rpm 25-28 water pressure the motor droped from 5600rpm to 2700rpm WOT and died, motor cranked back up but would only do 2700rpm-4100rpm with a strange knock so it was less than a mile from my house dock to get it home maybe 7 mins back at that rpm. you will see what the knock was, i can rebuild this motor i have rebuilt a car motor so with the pics and as far as i have gotten into it i would like to have any info on what anyone thinks, that would have leaned only one piston out and not the other one, being i have never worked on a 2cycle boat motor is there anything special i need to look at as the source of this injury. I have never heard of the top of a piston melting with such little damage and what would cause that, here are all the pics i have. also that is the only piston with damage i check the other three.
