Re: 2004 mercury 60hp 4 stroke starting & fuel overflow
I have a 2004 Mercury 60hp 4 stroke EFI outboard and it will not start. When I try to start the motor fuel comes out of a tube below the engine housing. Is this some type of overflow or pressure relief and what could be causing it or did I just flood it ? The motor has not been started in 6 months.
Overflow or vent,,, thats easy,, NO.
Any extra fuel is routed back to the tank. As for flooding it, if you flooded it so bad the fuel was running out of it then you have bigger problems.
Unless you have the proper tools and knowledge to work on this motor, take it to a dealer. The money you spend will be a good investment in not getting stranded out on the water.
I know its a little stressful parting with the cash, but when your hummin along with no issues, you will be very happy...
