2stroke1971
- Nov 8, 2009
- 209
Been working on my Capri that I bought a few weeks back, and now Im going thru the dash controls. I'm putting all new switches in for one thing.
My question is about how it is supposed to work. I say that because this boat has been redone before, some of the wiring and the distribution panel is not stock, that I know.
First, there is a TINY toggle switch named "main"...when you turn it on, the only thing I can tell is that the gauges energize..the needles all jump into position. (Even with no key in it)
Trim pump works no matter what, key or not, main on or not.
Accessory...the gauge lights come on, but again, regardless of main and key.
I would have thought that main would be a "main" disconnect...and would be a beefier switch. So nothing would work without main being on..or do I have that wrong?
Also, the key switch issue...how much of the boat should have power with no key in it? I would think the battery might be more apt to drain that way..
Bilge pump and blower I dont know about, they are not working at the moment so I dont know how they behave, or should behave.
Thanks in advance,
Neil
Thanks in advance,
Neil
