I know this sounds crazy, but I have a 3.7LX with oil in the coolant system. I flushed it in hopes someone inadvertently put a qt. of oil into the system, ran it and the oil reappeared. I've checked everywhere to see if there's an oil cooler, but I just find the filter housing with a screw-in bushing and o-ring. I also found an "oil cooler cover" on the bottom of the intake manifold with 2 passages that I assume line up with passages in the manifold. The breakdown didn't show any seals for the passages. Am I now to assume I have a cracked intake manifold? It seems to me it's the only place the higher pressure oil can penetrate the lower pressure coolant system. If the front seals were blown, I'd have coolant seeping from the weep drain at the bottom of the front cover and I don't. There's also no water in the crankcase and the engine runs good.
Has anyone run into this before or have a remedy?
