Recently a friend gave me an Aquabug boat motor that he couldn't get running. I'm not sure just which model it is. I thought it was the 1.2 as it has a two blade prop. Problem with that is everything I have read shows the 1.2 with a float bowl type carb, thumb lever throttle, and weighing about 13 lbs.
This guy has a diaphram pump type carb, no float bowl. It also has a twist grip throttle and weighs about 8.5 lbs according to my bathroom scales. It also has a single screw clamp to hold it to the transom instead of the double screw clamp I see on the 1.2 illistrations I've looked at. It's about 29" tall overall. I need to find a diaphram for the carb to get it running. I'm not sure what I have or where to find parts for it. Anyone have any ideas about what model this is?
Edit... I did some more searching and found this on ebay. It's the same exact motor that I'm looking for the diaphram for. http://cgi.ebay.com/ebaymotors/VINT...at_Parts_Accessories_Gear?hash=item27af6e82e4 He says in the description that he made the diaphram for it himself. Maybe I can get him to make me one.
