Last Fall, my friend hit a rock with his prop and twisted the prop shaft and bent it a bit. Everything still worked (FNR) and the lower unit did not get cracked or develope a leak. We got a new shaft and seal kit and when I put everything together, on the bench it seems to be stuck in Forward gear. The SN is OC 151547 and it's the type of motor that shifts from the tiller handle. I think the motor is a 95'.
Any tips??
Thanks much!!
Any tips??
Thanks much!!
