Have An 81 Johnson 28 Hp.rebuilt The Carb Last Season And It Ran Perfectly All Year.a Friend Put An Old Tank On It With Old Gas And Thats When The Problems Started.it Will Crank But Not Idle.the Long Idle Adj Screw On The Front Of The Carb Has No Effect.took It Back Apart And Cleaned.i Did Not Take The Big Screw On The Bottom Of The Carb Out.it Looked Like A Drain.is There A Main Jet Behind This Screw Up In There?
