Re: 1968 18hp johnson?
I've got a '57 18hp johnson. Absolutely love the motor. Very solid and reliable. I know my motor is older and uses a pressure fuel tank, but if yours is in good running condition, these old johnsons are pretty solid...and easy to work on. BTW, I have motors all in the '50's and '60's vintage from 3hp to 33hp, and they're all great runners. Personally, I would take them over modern motors because they're so easy to repair and maintain by yourself and parts are readily available. If you can make your way around one motor, the others are pretty much the same.
