Re: First timer!!
Hello to all I just recently acquired a 1974 signa delta trihull 18ft boat with a newer trailer and a 115 hp mercury outboard motor. I have never had a boat beforeand any advise about storing or general maintenance would be appreciated! first off where should i buy a cover i found 1 on this website for $160 is that a decent deal? the previous owner did not take care of it as well as id liked and i need help with the basics!
thanks to all in advance!
Born in Chicago Heights, raised in Olympia Fields...damn, you picked a helluva time to get a boat!
First, get her cleaned out of any accumulated crap (leaves, twigs, etc) and get her under a big blue tarp that you can tie down to the trailer. Leaves and crap hold a lot of moisture, which contributes to mildew and bug infestation. No use spending money on a boat cover that might be well spent elsewhere. Put a pole in the middle between the driver and passenger seats with a flat on top so that any snow will just roll/fall off over the gunwales.
When you get some decent days, peel the tarp back so you can climb onboard and start to assess what you have. Look at your wiring under the helm, the wiring and condition of the pumps in the bilge, in other words, familiarize yourself with the boat. But don't pull that tarp off, as you and I both know Chicago can get some really good snows come late April...
Given the age of everything, I would suggest buying a portable 6 gallon gas tank and try to run the motor on a decent weekend to see just what she'll do. When was the last time the boat was used? Do you have any recent info on her, as far as what type of maintenance has been performed?
But get her cleaned up and covered, first. Worry about the rest when the weather gets tolerable...
