Securing windshield to upper aluminum frame
mquail
Recently the aluminum upper windshield frame (that contains the roll glass clips) started lifting away from the glass windshield on the starboard panel of my walkaround. I added roll glass extenders and it is still happening...so it is not due to shrinkage of the canvas/glass.
I've tried lifting off the aluminum frame, resetting the U-shaped gasket, and reinstalling everything. As soon as I get the boat up to speed the gap starts to appear between the frame and the windshield (and i start to get wet).
There is a slight indentation in the glass where a fastener could possibly be used. But I would have to drill a hole through this in order to fit in any kind of fastener. I'm very concerned about doing this since the glass is no longer manufactured and I'm worried about doing anything that could break the glass.
Would a brand new gasket provide enough friction to hold everything in place? Is there a sealent I could use? Should I pull out the drill and take my chances?
Any suggestions?
Bob_VT
Re: Securing windshield to upper aluminum frame
Welcome to iboats!!!
If it is a boat that is trailered....... I would stop at a shop that does automobile glass. If they can not fix it mechanically they will certainly have the proper sealant ;)
mquail
It's in the water without a trailer. Hoping I can do this myself. Any suggestions?
Ayuh,... Lift the offending piece as far as possible,...
Clean the surfaces as best as you can,...
Then glue it back together with 5200,....
It'll NEVER come apart again....
The only drawback is, 5200 is white... Just wipe it clean before it sets up...
