My motor is the 4.3 with a sx-c1 drive with 1.79 gear ratio. I want to change to a duo prop. Do I need to change to a higher gear like the 2.30 that came factory with the dup prop boats or just leave the 1.79 gears in it and get different props? I did search but found nothing specific. from what I have found with the sx-c1 lower unit I can just find a dp-s lower unit and swap them. IS this corrct in my findings?
