Hello,
I winterized the boat for by adding staybill and runnig for 10 min.
Last month I got the boat out and it would not start. It would burt and stall.
We took the carbs out and cleaned them good. checked spark and have spark on all 4. Afrer replacing the carps and plugs it fired right up and ran great for 20 min on the muffs.
Next time I got a chance to take the boat to the lake 2 weeks after (a cold front 20 degrees) the engine did the same thing, it will burt after crancking for several min. and stall. took the carbs out and cealed with B12 and put back. got new gas in the can and flushed all the system, replaced the pump parts with new ones. got new gas lines for everything.
We got it to run for 10 seconds or longer (burping and misfiring) on 3/4 throttle but will not idel at all and wont start at idel.
checked comp. 120 +/- 5 on all 4
Please help.
Please help.
