Changing gas tank for Sport craft 20'
solanoi
I have a Sport-craft boat 20' and I'm restoring everything while ago i found a leak on the aluminum gas tank so i decide to replace it. now i have a jonhson 150 v6 and i would like put a more capacity gas tank. Anyone can suggest me
the maximum capacity for this type of boat (20'). my older tank was 40gl
Re: Changing gas tank for Sport craft 20'
Ayuh,... You can put in as Big a tank as you can Fit....
jonesg
I have a 20' with Johnson 150hp, I removed the leaky tank and put a bigger one in, its too big to remove without cutting the deck now.
I had the deck off and didn't notice until the deck was glued back in place that the new tank is bigger than the tank hatch. doh!
But just do it right and forgetaboutit.
Re-plumb the fill and breather hoses while you're in there.
Take measurements and watch craigslist, I got a new alum tank for $100.
Install it like this and it will not leak.
Don't pack it in with foam.
http://www.yachtsurvey.com/fueltank.htm
