Re: shift pin on drive shaft HELP!!!
It shows on my system as a 1981 50hp, but it has 4 cylinders....
Ok, driveshaft pin... None of the manuals I have show a replacement procedure, but the parts listing shows a part number for it and the spring below it. I do know that it's retained by peening the top of the driveshaft. What I would do is to open up the peens and remove the broken pin and spring, then get a new one and put a couple of new peens in.
Good luck.........
