BanjoRed145
- Jan 24, 2010
- 11
My 1957 Johnson 35hp project engine came with the recoil starter already removed, I fixed the starter and mounted it back on but I don't have the screw and washer that holds the lockout lever in place. I just have a generic Clymer's manual and I need to know what size screw and/or washer I need to use.
Second question: What is the thin metal strip that slides onto the brass rod on the top of the recoil starter and then connects with two screws on the back of the engine and has a little nylon thing that slides in the grooves on the recoil starter? Again this was already apart when I got it but I can't even find the part in my manual. I can see how it goes together but just wasn't sure what it was and didn't even know how to search for it since I didn't know what it did:redface:
A follow up question to the above would be what size screws should I use on said metal strip, since the screws for that didn't come with it either.
Thanks a bunch for any help!!!
