gimbal bearing replacement
SamLin
I have a 1987 Bayliner with an OMC out drive, it's noisy at idle and worse when I turn . Been told its the gimbal bearing. How difficult is it to change.
bruceb58
Re: gimbal bearing replacement
Could easily also be the u-joints. How often do you pull the drive to inspect these and align your engine?
mpsyamaha
pulling the drive is not that hard. take it off and look. usually if you have a lot of noise and vibration the u joint is bad too.
bruceb58
Sam...why don't you take the advice of the last time you posted this question 2 months ago?
