1972 Arrowglass Tarpon Project
cleaver
Hi my name is Mike here is my boat project it is a 17ft Arrowglass Tarpon I no very little about fiberglassing but im going to learn I have removed the deck the foam and the stringers They were all rotten I would like to relocate the steering console to the center of the boat I am needing info on achieving that pictures would be great
s86
Re: 1972 Arrowglass Tarpon Project
I finished a 1976 Arrow Glass Tarpon 15 foot the same color as yours last year. I had to repair everything including a lot of fiberglass on the keel and the floor. I also knew nothing about fiberglass, but you become an expert really fast. Best thing I did was buy The Fiberglass Boat Repair Manual by By Allan H. Vaitses. They sell it here on iboats and other places. I had my boat off the trailer and upside down for a long time and every part on it has been gone over. From the rebuild of the trailer to the carpet on the live well. I love this boat and it is fantastic in the water!
I have hundreds of hi res pictures detailing the process if you need to get a look at something before you start.
Good luck!
cleaver
Thanks s86 I would like to see pictures of your stringers before you put your deck on
s86
I did not have to remove the entire deck. But here is what my dad and I did. I removed rotted parts and removed the entire center channel. Drilled holes in the deck on the outside of the stringers to allow access to pour in foam to completely fill in the cavity. It shored up the floor very nice. I filled in the center cavity where the old water logged foam was with new foam. I estimate that I used a third more than Arrow Glass did. The entire floor is well supported now. I did use 3/4 inch plywood in the places that I needed new deck instead of 1/2 inch because I wanted a nice strong base to screw the pedestal seats to. Was a little hard to get it perfectly flat though. After carpet you can't tell.
s86
Here are more pics of the deck repair
Isaacm1986
Looks like it will be a fun project!
s86
Not as fun as the first day in the water.
cleaver
Does any one have pictures of how the cables would get ran if i move the steering console also i will try to post some more pictures if i can figure out how to resize them thanks MIke
cleaver
Here is a photo of the hull after deck removal
