Merc 25 2 stroke tiller- can't pull up motor stuck /frozen
Sonofjah
My merc is a tiller works fine steers fine but the manual tilt is frozen. Any ideas? How to fix? Etc?
will941s
Re: Merc 25 2 stroke tiller- can't pull up motor stuck /frozen
Spray some Break Free, PB Blaster or WD40 on the tube, and any part that moves with the tilt on the mount, let it sit for a couple of hours. Reach behind the mid section and lift the locking jaws, grab the mid section and PULL. When you get it to move, spray everything down again, PULL....keep spraying and pulling. When you get it move up all the way, lower and raise, lower and raise until it frees up all the way. Just keep working it with penatrating oil, eventually it will work like it should. Then keep it lubed to keep it from sticking again.
Sonofjah
Tryed it. Was only able to get the motor to move Dow a few inches then bac up the same. Any specific way to remove the tube and buying a new one?
Sonofjah
Got it! Thanks for the help.
