Please Help!
I have a 1982 15HP Johnson that I need to replace the prop on. The prop is slipping. I've been to the local "prop shop" and it's going to be $40 to fix it. I can buy a new one on iboats for $60 including shipping. I figured I would go ahead and spend the money for a new one. The old one is 9 1/2" diameter and 10" pitch. The only thing listed on iboats is a 9 1/4" diameter. How much, if any is this 1/4" diameter difference going to effect my performance? I use the boat less than 12 times a year. Mostly duck hunting. I fish with it as well, but use my trolling motor only. Also, can anyone reccomend what size pitch I should be using. I've been told by a "buddy" that I should go down in pitch, because I'm usually pushing a lot of weight. Usually 2 men around 225lbs each and an additional 100-125lbs of weight. The old prop seemed to work ok. This is my first boat, so I'm new to all of this. Please help.
Thanks!
Thanks!
