My 1979 115 hp Johnson V4 has never throttled up past 3000 rpm since I bought it a year ago. I recently noticed that when I push the throttle control all the way up, the throttle arm sticks about an inch before it gets to the WOT stop. It looks like the spring in the arm just isn't pushing it all the way. I can push it with my finger and I've sprayed a little wd40 on the joint but it's still not making contact. Is there a better way to lube this? I can also jiggle the throttle arm a little like it's loose. Should I go ahead and just replace it? How hard is that to do? I have an identical parts motor with a good tight throttle arm that moves the way it should and I could use it.
