Alohawhaler
Thread starter- Joined
- Jan 25, 2010
- 2
Firs,t I want to thank all the contributors to this site because it helped me so much in rebuilding my '67 whaler and tinkering with my engine. Unfortunately, my 2001 Nissan NS25A, four stroke, is not as nice as my whaler is. I bought it off a pretty shady guy, and it was obvious that it had some issues. When I first checked it out the engine purred like a kitten and seemed to run great on the back of this guys boat. The second time I checked it (the price was reduced dramatically) it did not run as well. So I compression tested it, all cylinders were within 5 psi of each other, and bought it. After cleaning out all of the carbs and putting in new kits, new spark plugs, a new coil, water pump, fuel lines and oil it worked muuuuch better. However, it still ran a little rough. I have to push the throttle forward a number of time before it starts, and if I lift up the choke it dies completely. When I did the water test it will ran on idle all day long and purrs until about half throttle, however, it does absolutely nothing when I increase the throttle, even when full. It does not die, but the engine does not seem to react at all to the increased throttle (and I know the linkage is okay). I removed the spark plugs and saw that there was some gray residue on the top two plugs, and the bottom plug looks brand new, but a little "wet." So I ran it again and when I removed the bottom plug boot from the spark plug there was no change in how the engine ran. I spark tested the coil to that cylinder and it had a good spark. I also changed the plug, but still no change. I have read similar problems which have been caused by either a faulty fuel pump or a ruptured head gasket. However, none of the previous posts mentioned anything about the engine dying when the choke is lifted up. So I am hoping that someone can help diagnose the problem based off this and the other problems. Thanks so much
