Fully_Loaded1
- May 24, 2005
- 58
I have not been on here much as my motor has never given me an ounce of issues. The other day I headed out for a day of scouting and everything was in check. Ran for about 30 min at cruise then pulled the throttle back and eased of to a bank to have a look. Went to power back up to cruise and the motor sounded the alarm and would not let me exceed 2500 RPM. Pulled the throttle back and checked everything out. Good stream of water, oiling properly (light smoke at idle), head was not hot, and running well under 2500. We ran 2000 RPM for another 15 min then I decided to try and power up and off we went. Ran another 30 min and pulled back to about 23-2400 RPM for a few minutes and went to power back up and it did the same thing. This time I pulled it back to idle and shut down. Waited about 10 sec and cranked it back up and it was fine. We headed back to the ramp after this and pulled it out. I figure it is a sensor of some kind going bad to tell it to go into limp mode or something to that effect. the only thing I can think that I have done is spray the motor down with corrosion block 2 trips before. Any ideas? It is a 1998 model. Thanks in advance.
