2003 Johnson 140 tilts down but not up. When I push the buttons up (motor or helm) I hear a click but no electric motor sound or movement. When I push the buttons down the tilt lowers the motor. I have read about a possible relay problem, but where are the relays. I found a fuse cover box that has 2 30A fuses inside and one has power to both sides all the time and the test light dims when the button is pushed down. The other has no power to either side of it at anytime but the fuse is not blown. Help if you can.....Dwight.
