Hi All, I new to this forum and live in Brisbane Australia. I have read through some of the posts on here and the information available is great and so far has helped me out heaps.
I am hopfull that I can get some similar help/advice with some issues which have come up with my boat restoration experiences so far.
I am also new to the boating world and have recently bought a 16ft half cabin fishing boat (Sunchaser 4.9..think it is a local Australian company. Year of hull is around the 1991 vintage I think)
I bought the boat from an ex boat builder, and being relatively green had sought some advice on what to look for when buying...I was advised that the main areas to check are the floor and transom. The floor has no spring and from what I can tell is sound (carpeted though so not visually checked it) and the transom also appeared to be OK...I spoke with the guy I was buying the boat from who told me that the transom and floor were OK (as I guess he would)..I rocked the motor on the transom and there was no movement/flex so believed (and still do!!?) that the it is strucurally sound (the guy also had another boat there which had a rotten transom...he showed me this and I rocked the motor on that too for a comparison...BIG difference, which made me feel confident that the boat I was buying was OK).
I decided that I wanted to give the 1988 Johnson 70hp outboard motor a makeover as there was a fair bit of corrosion around the steering arm and tilt ram..so I have removed the engine from the boat and am in the process of a full strip down and then will restore the parts.
Once I hade removed the motor I noticed that there was a small crack in the gel coat beneath the aluminium trim which lines the top edge of the transom in the motor bay. I decided to investigate further so removed the trim, which was held on by SS screws; the trim also had a smearing of silicon on the flat edge (against the vertical face of the transom).
Once I got the trim off it revealed a large crack beneath it, running the entire length of the transoms top edge (all the way from the hull seams on the stern, running along the outside face)...bit difficult to explain so I have attached some photos which I hope goes OK and shows the area in question.
I am not quite sure what to do now ...I have had a poke around in the holes revealed in the transom from removing the engine mounting brackets and it doesnt seem to be soaking wet, also tried to look beneath the crack but it is difficult to tell if there is any dampness in there. The cracked area does not lie beneath the water line so I am hoping that I can prove that the transom is not rotten and perhaps carry out some form of repair to the cracked area. My gut feeling is that I need to cut out the cracked area and perhaps check underneath to make sure, and also restore the area to as it shuold be.
I have also checked on the inside of the boat and there doesnt appear to be any cracks on this side, although it looks like the engine bay is pretty much stuck to the transom during contruction...not familiar with boat building so I can only guess.
Any comments or help/advice would be really appreciated as I am a bit concerned that there could be major work to do in carrying out a repair. Also I need to convince myself that the transom is OK and not rotten, and doesnt need replacing.
Many thanks
Many thanks
