Have a long go with an engine problem, which was originally to be a simple exhaust gasket replacement. Ha,ha. Broke bolts off in taking off plate. Any, took to a mechanic, and found that I also had a damaged piston(scared) and I needed to address it. This was in June of 09. Was told that that engine was worth nothing and I should look at replacing it. After looking at the cost of repairs of $2500 we went looking for mercury to keep wiring harness,ect. Prior to this, was told could not get a rebuilt powerhead, parts hard to find. After searching on my own, found that not to be true. I have boat back now after 7 months with all components. Had to have powerhead sent to machine shop prior to get out some twisted bolts out and sleeves inserted. I am thinking about rebuilding this engine and need to know if I can replace only the piston that is scared and then do all rings. Also, do I need to do other items, other than gaskets. I only have 45 hours on this engine and all internal areas look like new. The piston that is damaged on the top. Have priced engines, but hate to trash this one due to being in almost new condition. Block was honed while at machine shop. Any info on this matter would be appreciated.
