Bluewater2002
- Jan 26, 2010
- 1
My VP sx 5.7 engine started to "slip" and loose power after running for about 30 mins. The sound is as if the engine is on high RPM but not engaged in gear., when I idle down, the prop gets "engaged" again. I have checked the Porp and bushing no problem there. I just spoke to a mecahnic who told me that the "torque disc" from the engine to the outdrive is worn out. he felt with bhis hand and the rubber gasket was hot and melting. Does anyone know what he is talking about, what would I need to replace to fix. This mechanic indicated that the entire engine must come out in order to fix.
Thanks
Jon
Thanks
Jon
