perrosuperior
Thread starter- Joined
- May 6, 2009
- 50
Hello all. Let me apologize in advance if this has already been covered. I tried searching and didn't find what I was looking for. I am in the market for a new to me boat, and have found one that peaks my interest. There is a problem that is plaguing me. In another post I mentioned this boat and the fact that it has a yamaha drive on it. The initial response was run, don't walk, and I understand that as it appears as though parts are becoming hard to come by. My research shows that these are relatively durable drives when taken care of, and that if there is a problem that I can't find parts for, it can readily be swapped to a mericruiser drive. Is this the case? If so, what would a repair like this cost. Ultimately what I am trying to determine is if all things equal, will the outdrive make that big of a difference? Assuming I bought the same boat with two different drive configurations, both had catastrophic failure, and both needed the same repair, would it be cost prohibitive to have the yamaha as opposed to another boat with, say, a mericruiser already in place?
Thanks in advance!
-Jimmy
Thanks in advance!
-Jimmy
