Can you use 90 wt Pennzoil gear oil, or dose it have to be Marine oil?
R ron755 Seaman Apprentice Joined Dec 2, 2009 Messages 44 Jan 24, 2010 #1 Can you use 90 wt Pennzoil gear oil, or dose it have to be Marine oil?
Gary H NC Fleet Admiral Joined Dec 1, 2005 Messages 8,972 Jan 24, 2010 #2 Re: lower unit oil ? What lower unit are you working on...year,make,ect?
R robert graham Admiral Joined Apr 16, 2009 Messages 6,908 Jan 24, 2010 #3 Re: lower unit oil ? You should use a marine specific lower unit gear oil, not automotive gearbox oil. Marine stuff has certain corrosion inhibitors in it. Good Luck!
Vic.S Rear Admiral Joined May 4, 2004 Messages 4,699 Jan 24, 2010 #4 Re: lower unit oil ? An outboard gear oil is to be preferred because it contains additional inhibitors to guard against the effects of water ingress .... or so they tell us.
E ezeke Supreme Mariner Joined Sep 19, 2003 Messages 12,532 Jan 24, 2010 #5 Re: lower unit oil ? Pennzoil (Shell subsidiary) makes (among several) a good 100% synthetic marine gear oil - I've used it for years. You can use it wherever OMC/BRP Hi Vis would be used. http://pennzoil.com/documents/Pennzoil Marine High Viscosity Lower Unit Gear Lubricant.pdf Here's a link for some other information: http://www.bwbmag.com/output.cfm?ID=1891729
R ron755 Seaman Apprentice Joined Dec 2, 2009 Messages 44 Jan 24, 2010 #6 Re: lower unit oil ? Thanks, I'll get the marine oil.
Gary H NC Fleet Admiral Joined Dec 1, 2005 Messages 8,972 Jan 24, 2010 #7 Re: lower unit oil ? The Pennzoil 80W-90 Marine gear lube is sold at many auto parts stores. I know Advance and Autozone both carry it. About 6 bucks a quart.. Many people run the Mobile One GL-5 rated synthetic.
