lindy46
- Nov 27, 2008
- 3,886
Got the wiring all figured out on the Lark, and have a question on the Safety Switch. From the looks of the wiring, it appears the safety switch functions in the same way as the old mercury switch? If the throttle advances too far, it grounds the solenoid preventing the starter from turning. Is that correct or does the safety switch prevent spark to the plugs? The reason I ask, when I first put power to the engine, I momentarily had a strong spark to the top plug (I was checking compression at the time). When I switched to check compression on the bottom cylinder, I had no spark to the bottom plug. I then rechecked spark on both plugs and had none. I haven't been under the flywheel yet, so I don't know the condition of the coils. The starter turns over the motor at any throttle setting.
