Here's the needed info:
1. I want to switch from the current OEM aluminum prop to a Turbo Hot Shot prop and need to know what pitch to go with.
2. Current prop: Aluminum Yamaha part # 6H5-45945-00-EL. (Cupped Prop)
3. Diameter: 10-5/8x13
4. 31mph (GPS) @ 6200rpm
5. Yamaha F40TLDR 4 stroke 2005 40hp
6. 2005 G3 Eagle 165. 16' 5" advertised hull weight 860. Motor dry weight 198.
Hole shot is pretty good for a four stroke. I should be able to raise the motor up one hole as it gets no venting in turns with the motor trimed up.
Thanks,
Mike
Thanks,
Mike
