resealing lower gearcase 1960 johnson 40hp. new propeller seal from sierra is different from original seal. should it be installed the same way as original witch doesn't look right. spring facing gearcase no metal covering spring original seal does .Or install with spring facing toward propeller meaning spring will get wet and rust?but that looks the way they want you to install it. hopefully someone has run into this problem. any ideas
