Re: primer bulb
A poor O-ring seal in a fuel hose fitting may allow a small amount of air to leak into the line, at low speeds the motor can act like it is running out of fuel.
Temporarily install a clear hose between the fuel pump and carb so you may watch for any air bubbles in the fuel, indicating air leaking.
Check ALL hose fittings, clamps and hoses, until you cure the leak.
Be sure to remove the clear hose once finish, it is NOT recommended fuel line and should only be used for testing.
