motorguide wireless trolling motor no foot pedal or fob
stevensmithnc
I aquired a motorguide great white lazer 2 trolling motor model number GW62RF but it did not come with any controls. if i hook it to a battery it turns on and runs so the motor is good. how do I know what Fob to buy for it?
stevensmithnc
Re: motorguide wireless trolling motor no foot pedal or fob
Also lets say I dont want to spend the money for the fob...... could I hook some kind of dimmer switch to it and manually control it?
Silvertip
You will need to contact MotorGuide with the serial number/model number so they can advise which FOB or foot pedal you need. These are essentially radios and since specific frequencies are involved, the transmitters will need to match the motors. As for a dimmer switch to control things, the answer is no. You need several functions 1) on/off, 2) speed (fast to slow either switched or variable), and then there is right and left steering. This is all electrically controlled and to build something would cost as much as the regular control Once you determine what's needed, check E-bay.
