Re: 1960 40 hp johnson seahorse ( Compression )
The carb is probably full of junk, got spark on both plugs? I bought a 1964 40 hp that hadn't run in 2 yrs and had to clean and adjust the points, clean the carb, do a link and sync, replace the water pump and change the plugs before it would run right. Your motor is probably going to need some attention before it will run properly, 6 yrs is a long time without use to gas it up and go, especially if it wasn't put away properly.
Check the easy stuff first, these motors will have no power firing on 1 cylinder, they idle nice on 1 cylinder, it's to trick us owners. Then clean the carb, it's a must.
