I have two AQ131D motors with SP-A outdrives. The starboard outdrive does not trim up or down. When I push the switch, either up or down, I hear the relays clicking (both ways) but don't hear the motor trying to run. The port side one works. I checks the wire connections for both relays and motor and they look fine. Where and how should I start to diagnose this problem. Should I take both wires coming out of the motor and connect them directly to the battery to see if the motor is working? I wanted to but didn't want to burn anything up, uneccessarily. The cost of Volvo parts has been adding up toooo fast. My other thought was to change the motor with the port side one, but not the easiest to get to and trying to save my knuckles from anymore blood shed. Thanks for the help.........again!!!!!!!!!!!
