Thank you Bob! Is mine a rotary system?
Be sure to clean the inside of the tilt tube,this is critical for having smooth steering.I normaly use a 5/8 drill a couple of passes is all thats needed.Put some 2-4c or never seeze on the cable when installing.GL,Ted
Great information guys, Thanks! I'll disconnect the cables from the motor first. If I do need to replace them, is it very hard??? Again, Thanks!
