Dont put them on a bare concrete floor. Put them on top of a couple of 2x4's.
Old, old info.
Not an issue.
Do you mean putting a battery directly on a concrete floor is not an issue?
If you leave a fully charged, properly filled, and disconnected battery in your boat all winter, it should be able to start the boat in the spring. If not, then it needs replaced. The cold only hurts them if they are discharged, then the freeze and break.
I ... charge them once a month. I don't have a battery minder YET !!!
