brihen
- Oct 3, 2009
- 32
I have a 60hp 4stroke Yami (2006). I have run it in the yard using only the hose connection, with no (so far) apparent problem.Now I have heard flush muffs should always be used. It looks like in the manual it says to use the muffs to "flush" the cooling system?. 1. Is it OK to use the hose connection just to keep the motor cool while running it,and not trying to flush the system ? 2. What is the upper hose connection used for? 3. What would be the safest way to fire up the motor in the backyard? 4. where can I get these muffs? (I did not find any on this web site)Thanks.
