Hi Guys,
I am a first time boat owner and I have resently bought a 16" Boat with a 1986 Mercury 135HP V6 Oil Injected motor. The problem I am having is that at idle the engine runs fine and my temperature guage sits on about half way. However, if I put the boat into gear and the engine runs between 1000 and 3500RPM, after about 5 minutes, the temperature gauge goes to HOT. If the engine is running at over 3500RPM, the engine then begins to cool and after about 5 minutes, the temperature gauge drops to on or below the half way point. I should mention that there is steady water coming out of the small "wee nozzle" however it very hot. It is almost impossible to keep your hand on this water.
Would you guys have any idea what the problem may be? I have not yet had a chance to change the impeller but will do so however if it were the impeller, would it not run hot especially at higher RPMs?
Also, when the temperature does get to HOT, the alarm does sound.
Thanks in advance,
Callala.
Thanks in advance,
Callala.
