hello thanks for looking I have a 7.5 mercury outboard
and I cant get the thing to kick over I checked compression both cylinders have 120 psi cleaned all the fuel lines
the carb checked the fuel pump and Im getting fuel to the carb
checked the reed valves checked spark and timing have good spark, but still can't get the thing to crank sprayed gas mixture into the cylinders had it
sputter one time but wont crank?? any ideas would be helpful thanks.
